1 - 12 of 12 Posts
Well my headers are leaking again! Right now I have Percy's seal for good gaskets. A guy at a local shop told me to go back to the stock gaskets. I remember how thin they were and don't see them fixing the problem. This will be my 4th set of gaskets.
1.copper Horrible!
2. Percy's seal for good
3.graphite gaskets out of a hot rod magazine
4.Percy's seal for good with copper spray
What do ya'll think?
i have felpros on mine with no problem after 3 years...maybe its ur bolts losening up...what r u using?
I reused my old gaskets and studs and everything has been great for over a year and half now.
are you sure nothing is cross threaded and its not flush, are they good name headers?
warped flanges would do it also
there BBK lt's with stage 8 bolts. i tightened them from the inside working out. I checked them and there all still tight.
its gotta be the flanges then...do u know what thickness they are?
Discussion Starter · #11 ·
i/m sure there leakin from the flange and there pretty thick. It sounds like its only the driver side, which is the on I've had a problem with the whole time. BBK even exchanged the header for me and it still leaks.
1 - 12 of 12 Posts
