1 - 4 of 4 Posts
Ok,
So here is what I bought to fix the hyper flash(LED tail lights) and it worked great till it dropped -5 out side and it made my tail lights fix stop working and strob when I hit the brake:
(I don't know if this is what i bought but its what it almost looked liked)
So I put back in my stalk not LED lights and they worked great but I want to put back in my Black LED sequinsed(killed that word) lights. Will this fix the hyper flash?
Heres the link to the part: All Dodge/Ford Vehicles Hyper-Flash Fix Electronic Module for LED Turn Signal - Single
If that will fix them where does it go? Under my steering wheel?
Thanks for the help!
Wax on, Wax off
So, if I am reading this correctly (you have a ton of grammar mistakes), your issue is your LED lights flashing to quickly (Hyper Flash)?
That relay you posted says it is made to fix that, so yes it should work and yes it would go in your fuse box. I imagine it would replace the stock flasher. It's probably in the engine bay fuse box.
1 - 4 of 4 Posts
