1 - 6 of 6 Posts
2000 Mustang GT Auto : 3XX whp & 3XX rwtq Procharged & Intercooled
SLP LM1, O/R X-Pipe, C&L Intake Plenum, BBK 70MM TB, Diablosport DynoTune, 4.10 Gears
Black Bullit 17x8's up front & 17x10.5's in the rear wrapped in Nitto N555's
i guess ive never checked the temps but when its cool out and i can see the steam from the exhaust my drivers side seems to give off a bit more.
not sure what part of the exhaust your talking about but the only thing that would make one side hotter than the other would be from one side running leaner than the other. since your sc i would run a wide band on each bank and check to make sure they are both running the same. if you do not have a wide band you can try and run your handheld tuner in short and long term fuel trims and data log it.
With an X pipe wouldn't the air mix together from both banks?
1 - 6 of 6 Posts
