not sure about the formula but I found this ay another site......................Considering you're adding those particular heads, you should be able to use the 1.7's. The specs for the B303 with a 1.6 rocker is .480 gross valve lift. The same cam with a 1.72 rocker will then be .516 lift. The stock 1991 pistons have 4 valve eyebrow reliefs and can accomodate approximately .535 lift. You should be ok but check piston to valve clearance before starting the car. While at it, check the length of the pushrod too, make sure you get the proper length to maintain valvetrain geometry.
