21 - 40 of 47 Posts
Mustang Lighting Experts
Discussion Starter · #24 ·
2015-2017 Ford Mustang Front Turn Signal Assemblies by Diode Dynamics
Our new Sequential LED Turn Signals for the 15-17 Mustang are available now through our website, and through our authorized dealers! Computer-designed using optical simulation software, they add a bright, crisp white running light with a highly efficient SAE/DOT compliant beam pattern!
The turn signal is nearly twice as bright as the factory turn signal, and features a programmable sequential blink rate for a truly custom look! Available with smoked or clear lenses! #MadeinUSA
Nick C.​
Discussion Starter · #33 ·
https://youtu.be/7ZebE6DpLLg
Measuring Headlight Output | Diode Dynamics
How are headlight output patterns measured at the factory level? How do you test to see if a headlight is meeting SAE and DOT beam pattern requirements? Here at Diode Dynamics, we've invested in a goniometer to accurately measure and map the entire beam pattern and ensure our products are adding light output without adding extra glare.
Check out the video to see how it works!
Jake H.
Diode Dynamics
Discussion Starter · #39 ·
LAST CHANCE TO SAVE!!!! Until 11:59 p.m. CST on 5/29/2020, you can use coupon code "USA20" at checkout for 20% off you're entire order of lighting upgrades, including our
LED bulbs, sidemarkers, light bars and more!
Don't wait, this sale ends TONIGHT!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 5/29/2020. Cannot be combined with other coupon codes.​
21 - 40 of 47 Posts
