1 - 8 of 8 Posts
Does anyone have any tips and tricks on how to get the oil dipstick reinstalled after installing longtubes? I finished installing my Kooks LT's and had the engine mounts and steering shaft disconnected to get more hard room, but I cannot seem to get the tube lined up snaking down the block, to go into the hole. I am just doing it by myself and I know a second set of hands could help but, if someone has a trick up their sleves, I would greatly appreciate it.
Sean
Undo the top bolt, get a bright light, and a buddy to help.
get underneath and using a pliers very carefully, wiggle the tube into the hole. I know it is a hard one to put back in, I had problem when doing someone elses longtubes
I figured it out tonight. There is this thing mounted on the drivers side strut tower that ahs a hose going into intake manifold. I know that on some of the 2005-2006 models this thing was in a different location than my 2007. i disconnected it from the strut tower a rotated it out of the way. By doing this, i was able to get the correct rotatin of the dipstick tube and got it into the hole right away.
Thanks for all your input.
Sean
Glad you figured it out. When I did mine it popped right back in without too much trouble... What kind of headers you put on?
Kooks with Catted H-pipe.
Good choice, bet it sounds nice!
It should, once it is all back together.
1 - 8 of 8 Posts
