I need alot of parts. Let me know what you have whether it is new or used. Here is the list:
- Tubular K-member and control arms
- manual rack
- aluminum street radiator for fox body Mustang
- Flex-a-Lite Black Magic fan for fox body Mustang
- Comp Cams 838-16 solid roller lifters
- Crane Gold, Trick Flow or equivalent 1.6 ratio roller rockers
- Edelbrock Victor EFI intake for 351W part number EDL-3887 or just the upper or lower is fine too. I'll take what I can get. A Victor 5.0 upper will work too.
- 351 EFI distributor MSD part #8452
- 42lb to 60lb injectors
- 87-93 Mustang adjustable fuel pressure regulator
- 90mm or larger throttle body
- 90mm or larger mass air meter calibrated for 42lb or larger injectors
- Electric water pump (preferably a Meziere but I will consider other pumps)
- Eaton 31 spline locker
- 31 spline stock length fox body axles with C-clip eliminators (Strange or Mark Williams preferably)
[email protected]
- manual rack
[email protected]
