1 - 20 of 36 Posts
I want a aluminum drive shaft too but @ 600+ bucks it aint cheap lol. Congrats let us know how it turns out in case i decide to pull the trigger
Do you have a bigger picture for your sig? That thing looks hilarious.
lol no thats the only size i found,
i should've asked around here if anyone was selling one. :( to late now.
The driveshaft that Steeda sells is technically a Spydershaft driveshaft?
Yes it is a spydershaft. If you want to get technical. They are all ford drive shafts. They come from danaspicer/ford and are modified to fit the new stangs. But the shaft itself comes originally from danaspicer. And yes steeda is buying them from him.
BASIC INFORMATION ABOUT SPYDERSHAFTS
-WEIGHT: APPROX 16.5 LBS
-DIAMETER: 3.5" TAPERING TO 4"
-MATERIALS: 6061T6 ALUMINUM .100" THICK TUBING WITH 3 LAYER INTERNAL DAMPER -SPICER 1330-SERIES U-JOINTS(can be upgraded to 1350 size for an addition charge)
-PRECISION BALANCED AND TIG WELDED
-HP RATING: 500+RWHP DRAG TESTED WITH SLICKS
-GAINS: .21 SECOND REDUCTION IN ¼ MILE E.T. ON A STOCK GT AUTO SAME DAY TRACK TEST BEFORE AND AFTER
-ALL NEW COMPONENTS FROM FOMOCO/DANA-SPICER corp.
-NO ADAPTERS TO VIBRATE
-DESIGNED AND TESTED FOR 5R55S AUTOS AS WELL AS MANUAL TRANSMISSIONS
-ABSOLUTELY OEM QUALITY
*DEALER INQUIRIES WELCOMED
1 - 20 of 36 Posts
