Status
Not open for further replies.
1 - 20 of 53 Posts
UNOH Suspension Enthusiast
I've got a 96 that I'm looking to boost a little. I want to put about 6 lbs to it, chip it, and put a cold air intake on. What's a fairly decent priced turbo kit for these motors? I'd be willing to do a supercharger, as its really whatever is cheaper.
um wow..id probably look somewhere other than f/i
waste of time unless you had a pre 99 honestly it wouldnt give you that much power and to remove and install a motor even for a cheap price just not worth it in the gains
ohh well not sure what the upgrade is there I would assume pretty decent but still not worth it I think going from a single to split is around 45+ hp(correct me if im wrong) and to put an m90 supercoupe swap in a split port only adds a little more so maybe 60 total. Id take that money swap in split port and a windstar which would give you very good gains and keep you under a grand maybe even throw a tuner on it too
heads are with that too and youd be better off with a split port and windstar swap than a chip and cold air but id think that what im suggesting would give you 60 maybe 75 with tuner..somebody else will chime in im sure
supercoupe motor swap it and be done with it.
or that..what power do they put out
Dont buy one of those ebay chips, i hope your talking about the SCT one.
Even so i would get an X3 over the chip
Dont buy a regular CAI either if you plan on going turbo as it will be useless to you. Unless you incorporated the piping into the cold side.
1 - 20 of 53 Posts
Status
