1 - 18 of 18 Posts
MM's Orangest
So I did a little driving last night and I got home and realized that my car had a horrible sound from up front. I could hear it over my exhaust and I thought it might have been my heater/defrost so I turned it off and it was still going. It was late and I didn't want to keep anyone awake in the neighborhood so I shut it down to wait until this morning.
It got cold enough to freeze last night so there was a little bit of ice around the shaker that was starting to melt. I turned on the car and the noise was still there. When I opened the hood, I noticed a little bit of water drip from the hood and it landed on the belt. The noise stopped for a minute and then resumed. So, I put a little more on and it stopped and started again. So I think I have it narrowed down to the belt but what can I do quiet that SOB down? I've checked the pulleys and they seem to be on there tight. Opinions?
MM's Orangest
A loud, consistent whine. I'd put a video up but I don't have an adapter here at home for my camera it's back at school.
MM's Orangest
The best thing I could compare it to would be a car running in cold weather with that kind of a whine, but usually that goes away after it heats up. And this is the first time my car has done this and it's been ran in a lot colder temperatures than this, this year.
MM's Orangest
Dad just stopped by on his lunch break and put some lubricating oil on the belt and it kept it quiet for about a minute and then it started back up again.
The Mean Green
Hit it with a bar of soap....old timers trick. But Id just replace the belt, and check the pullies.
Boost gets you laid
my car was doing something similar, it wasn't the belt though it was the idler pulley bearing. it was loud and annoying so i took the idler off and greased up the bearing and now its quiet again.
MM's Orangest
The belt just needed lubed. I went to go grab a birthday card for my dad and the sound was gone. I haven't done anything since the oil so I guess it just needed time to soak in.
ive had the same noise on several cars i would spray it with a lil belt grease...and the noise always came back...it was always the tensioner pulley that was going bad on me...just my .02
MM's Orangest
Discussion Starter · #12 ·
It's back. I tried adding some tension because I was told that would eliminate the sound if it was the tension pulley. It didn't. So I'm going to try out a new belt and see if that doesn't do the job.
MM's Orangest
Discussion Starter · #13 ·
Twas the belt. It's running all chipper now. And then the rain started...
MM's Orangest
Discussion Starter · #15 ·
I don't care if anyone told me so :). I was looking to do the cheapest repair possible first and then work my way up.
Retired MM Ninjas
LOL! I feel ya. It's called the process of elinination you start at the cheapest part and work your way until you fix it. Glad that you gotter done.
The idler pulley, or AC try running the A/C and see if it makes a diff. I threw a pulley at about 80k and don't live where it snows. Belt ran for 100k
N/A 4v Guru
You missed post #13 WP. :D He fixed it.
1 - 18 of 18 Posts
