1 - 10 of 10 Posts
I have a 96 mustang gt and is the low coolant light the Engine looking light with a fan(Dont have a manual). I recently nocticed the top of the radiator leaks a very very small amount. Would this cause the light to turn on. It also usually turns off as long as i keep it all the way full with coolant.
That depends. If you can watch your coolant level like a hawk, then you can do that. However, any leak you do have will not go away by itself and will probably get worse over time. I reccomend fixing small leaks before they become big leaks.
Im hoping its just the radiator than it barely leaks any.
mine came on after detailing the engine. it was from the belt slipping and not building pressure.
1 - 10 of 10 Posts
