1 - 8 of 8 Posts
Have roughly 1200 miles on my car since recent head swap. Noticed I'm a quart and a half low. ? See a little ill on my valve cover but nothing significant. Anyone have ideas
Is leaking out of the lower rear bc bolt...the lip of the bc has a puddle on it. I just don't know if that is a big leak like that
Quart and a half is a lot of oil. I would think you would notice some serious smoke blowing, odor, or puddles. Did you change the oil yourself after the rebuild? I was having gears done in my Camaro and had them change the oil while it was on the lift. Within a few days I spun a f'ing bearing. They didn't add the proper amount of oil if any at all. I always do my own changes but didn't that time out of convenience.
OIF 6 Veteran...
Check your coolant make sure its not mixing in the block just a thought...your water passage area of the head gasket might be leaking....
Sent from my EVO using AutoGuide.Com Free App
OIF 6 Veteran...
Surely if it was leaking on the upper half of the motor it would blow back on the exaust manifold which u would have def noticed.
1 - 8 of 8 Posts
