1 - 11 of 11 Posts
I just got new rims, as you can see in my signature, and for 2 days the low tire pressure monitor was off then after driving on the highway it turned on. How do I fix this, its annoying me.
Did you check your tire pressure? Did you re-use your old sensors?
If new sensors, did you sync the sensors to the PCM?
When I switched out my rims, I couldnt reuse the tpm sensor and didn't want to spend the extra 100(i think, dont remember). I just deal w/ the annoying sensor light on my dash.
If they transferred the tpms to the new rims, you are probably just low on air, temperature changes will do that.
When I am not running my stock wheels/tires(winter), I just deal with the light on the dash board not a big deal.
didnt feel like wasting money on buying tpms sensors for the aftermarket wheels.
I forgot to mention i have nitrogen filled tires and there are no tpms sensors on the wheels at all
when i get a tuner could i fix it with that?
i havent sincd my yet, so i have same thing pop up every now and then
its pretty easy just check ur tires, u can tell by looking for the most part if u need air
if it really bothers u just get sensors
Either get some sensors if they bother you that much, if not you'll just have to deal with the light. Doesnt bother me at all, get used to it.
Discussion Starter · #11 ·
I guess ill just live with it, thanks guys
1 - 11 of 11 Posts
