21 - 40 of 48 Posts
Discussion Starter #22
well i just looked at the bolts he used and they are a tad bit bigger meaning they wont fit through the poly bushing without pounding it through and ruining it. I guess i need 4 new bolts and nuts. Does anyone know what size or what type of bolts i need? when it comes to hardware im clueless lol
Discussion Starter #23
okay i found the bolt size to be 14x1.75x110. its grade 8 or 10.9 but i cant find it in any hardware store. And online you can only buy it from like upr or mm in kits with upper/lower control arm bolts for like 40 bucks plus shipping which is rediculous for bolts. Where can i get those 4 bolts for a decent price anyone?
Discussion Starter #24
Does anyone know how to do the bearing install on these j&m lowers? There's nothing
In the directions about it
Discussion Starter #26
Bushing lol sorry typed it fast
Discussion Starter #28
Well the bushings seem to have 2 ends and a spherical piece and the silver piece that goes through it, I assumed the spherical piece goes in the middle but it seems tough to get it in, maybe when I grease it it will just slide in?
I <3 Boost
youll need to grease the bushings other wise they will break themselves down from the movement from normal driving. the bushings will be a tight fit :yes
Discussion Starter #30
do i need to use a press to put them in or will i be able to do it by hand when there is grease because it will be more slippery?
Discussion Starter #32
So I put the lower control arms today and what a pain it was to get the rear bolt lined up. I took it for a test run and the rear end feels tighter but when I dumped the clutch in first gear there was still a **** ton of wheel hop so I feel disappointed I spent all day on it
Discussion Starter #34
They arent bad they are Pirelli p6 with a good amount a thread left, I thought I read that tires don't effect wheel hop as much as actual traction
Discussion Starter #35
One thing I noticed with installing was that no matter how much I tried to get all of the trapped air out from 3 sides of the control arms I couldn't get all the air out but I got most out. This made it a little harder to line them up to mount in the car obviously but I got them I'm and torqued them down and when I torqued them obviously they closed up and they are tight now but you dont think that makes a difference right? Everything is nice and tight since its in and the bushings are tight together because they are torqued tight
!FACEPLATED!
What trapped air are you speaking of? Cheap tires will produce wheel hop
Sent from my HTC Wildfire using AutoGuide App
  • Like
Reactions: FORDY9ER
Discussion Starter #37
On the j&m bushings there is some when making the bushings flush it says in the directions, I don't think it makes a difference ones I crank the bolts toght
Poo tee weet?
When you say air you mean the space between the bushing and where you bolt it to?
I must be making no torque because I get no wheelhop and the only time I lose traction is 3,500+rpm in 3rd gear on the highway.
Discussion Starter #39
Before the arm is on the car there is air trapped in the bushing that you use a screw driver to pry on it to get it out
Discussion Starter #40
Can over tightening the bolts make a difference ? I didn't have a torque wrench so I just used a regular wrench and torqued the bolts pretty tight so they don't come loose, I did this with it jacked up in the air if that makes a difference
21 - 40 of 48 Posts
