41 - 48 of 48 Posts
Discussion Starter #41
The suspension wasn't loaded either
Discussion Starter #42
So in conclusion I hate these control arms, the wheel hop is exactly the same and they make so much noise too, I'm putting stock back on
Discussion Starter #43
I'm going to try and get the air out of the bushings and see if it helps but I want to re grease them but I'm out of grease that came with them. What is a good alternative I can get at an autoparts store??
Discussion Starter #44
Hey sorry about bringing this back again but I'm going to tackle this install for a friend this weekend on his 02. I had two jack stands on the axle last time just like you do in the photo. The problem was that when i lowered the control arm with the jack and removed the spring, the axle shifted upwards on the side I was working on because the spring was no longer there to hold it down. It became a pain where I ended up having to remove the shocks and get everything lined up again with a friend. What did I do wrong?
Discussion Starter #46
Only two on the axle, is that why? Maybe I needed them on the frame as well
41 - 48 of 48 Posts
