1 - 20 of 44 Posts
· MM's Resident Ginger
And now she's got a clunk in the front end when she goes over speed bumps...it doesn't always happen although I mostly hear it on the left side. When I installed the BMR springs I also put on the camber bolts and Adj panhard rod...any Ideas? BTW I used the search function but was just getting irritated.
· Registered
did you reuse the stock strut mounts? if so thats most likely your problem ive got the same noise and its from reusing my stock mounts twice lol do your self a favor and pick up a set of caster camber plates( take out the camber bolts) J&M makes a nice looking set of CC plates for around $230
· Registered
Bout damn time. Post pics too.
And make sure you tightened everything down. I had a clunking noise after doing my suspension too, know what it was? My wheel wasnt tightened right all the way..dangerous stuff right there.
· Registered
If you shake the car or put it up on jacks and rotate the wheel, it might make some noise. I had my buddy listen as i pulled in and outta his driveway. Another noise i had was my intake was moving outta its hole on the underside of the heat deflecter.
· Registered
the nut that holds the strut to the mount if loose could cause that noise too also the sway bar endlinks could cause a noise when hitting a bump. and just cuz they tightend everything down when they installed it doesnt mean something couldnt have worked loose or they missed something ....... but seabee is right check over every nut and bolt one more time and if everything is tight and good then its most likely your strut mount
Discussion Starter · #16 ·
lol i'll check over everything asap. Is it something i should really be worried about? and if its strut mounts can i just wait til i get some new shocks/struts
· Registered
Quit buyin clothes and makeup and all that girly **** dammit.
I put all that on the gt at the same time just so it worked better. shocks/struts/springs/cc plates.
1 - 20 of 44 Posts
