1 - 12 of 12 Posts
pan hard bar is generally a good idea with any lower springs with those you might not need em but its possible and your camber might be sligtly off but prolly not by much
So is the camber something i would have to fix or replace? Or pick up something to fix its position?
well thats optional i didnt fix my camber but i drive on off ramps on a regular basis to fix the inner ware that creats but they sell bolts to fix it and they are usually only like $40 a pair
Camber bolts or caster plates
Camber bolts
Caster plates
Edit: Called caster plates, but will adjust camber and caster
IBEATU
You should get the adjustable panhard bar and LCA relocation brackets would be a good idea too. You can slot your factory struts and not have to buy camber bolts. By doing this you also have more adjustability with your camber
What about the roush leveling spring,would they require that pan hard bar also is a rear alignment something that is done on cars.
1 - 12 of 12 Posts
