1 - 20 of 22 Posts
ok looking at cams woundering what one would give my car that mean rough camed sound looking to spend no more than 5oo
the one that you titled your thread as
friend prity much has a shop in his garage so thats fine and ill look and thanks
1 Wheel Peel
Cam from comp 330
Gaskets 75ishh
Springs 70
Oil change 35
Cam break in lube 10
Tool rentals free
FREEEEEEEEEEEEEEEEEEEE :eek:
from where?
Put a deposit down on the tools with autozone, when you return them they'll give you your money back.
Cam from comp 330
Gaskets 75ishh
Springs 70
Oil change 35
Tool rentals free
Free.....dad is my labor...hahah as long as I help in some way he donest care
And I read your post mike...you only need new springs and retainers the lifters can stay right?
1 Wheel Peel
shouldnt you buy new retainers as well when buying new springs? or is it really not that necessary?
Sorry guys retainers as well.. I believe mike just used GT retainers where as I bought a new set from comp.. Both did the job
Edit: stock lifters are fine... Always a good thing to upgrade if your high mileage but I wouldn't say it's a must-do
Also I have been reading and talking to my buddy who also did a cam swap.. For the intake the pushrods need to be longer or you will get rocker chatter..
That info came straight from comp.
I checked my heads today and the intake valves had more valve lash... Weird huh
Damn by the sounds of thing todays been pretty shity
U cracked heads
Some retart at my work ran the tractor trailer in the gaurd rail
And today for me just blows
I believe the ls2 takeoffs go for that. Otherwise the 26915/918 can be had for around 130.
btw man, your car looks good in your sig. what springs and shock combo you running?
Thanks man. Cut and stock haha. Saving for cam, springs and dynotune :D
And wtf your in the 11's dude?? congratzz
Who is in the 11s and what did I miss ?
Well it looks like Jts running 7.48 in the 1/8 ~ 11.67 1/4. So ill just call it 11's. :)
Your still banging out those cams kyle right? Should need one soon
1 - 20 of 22 Posts
