1 - 8 of 8 Posts
I have an 03 mach 1 that sometimes just dies randomly even when driving it. Its like someone turns off the car and then it restarts just fine. I'm wondering if anyone knows anything about this?? What should I do??
Sent from my DROID RAZR using AutoGuide.Com Free App
Livin' the Dream
PATS?
I'm a newbie so I'm not quite sure what either of those are! Haha
Thanks for the responses though!
Pats is the Passive Anti Theft System. Basically a transponder in the key. CPS is crankshaft position sensor, it's bolted into the front cover of the engine and basically tells the ignition system when to spark.
Livin' the Dream
I had issues with PATS in my old v6. The car would basically start then die but keep running if you gave it gas. Then, eventually it would just stay running.
I Blumpkin Entirely Way Too Much
You're having several problems with that car, must be time to trade it for my gt... hahaha
I would check all of the grounds first.
I had this problem in mine, and it turned out to be a bad ground connection on the driver side, attached from the chassis to the forward most, lower engine mount bolt.
Also, I have had this happen when my crankshaft position sensor wiring was faulty. It would happen almost everytime it rained, and occasionally when it was nice out.
1 - 8 of 8 Posts
