1 - 9 of 9 Posts
Mach 1 running lean? With Video
So, the car idles like ****, rpms up and down then it will die at some point, but it comes and goes. I have a tunner on the way in hopes of fixing it cuz of my jlt intake, long tube headers, high flow cat back, and PHP intake maniflod spacer, I figured that's the cause. The check engine code says bank 1 and bank 2 are lean. I pulled my plugs and they looked fine and I checked the gapping, they were at 55, they werent burnt up, this site shows what a lean plug looks like #9, Reading Spark Plugs - Spark Plug Tech - Super Street Magazine
I've only put at most a 1000 miles on it with it doing this, but like I said it comes in goes, and thoughts anyone? think the tuner will fix it? its a SCT livewire from AM. Maybe there is oil on the mass flow air sensor?
Discussion Starter #2
here is a video, it was doing it for about a min or 2 before I decide to get it on vedio, runs like **** than runs like a top
FYI it was alittle chilly out, so that isn't 100% just smoke, it doesn't smoke too much
MM's Orangest
Did you replace the EGR gasket when you put on the intake spacer? My car did that except it would die after 10 seconds.
  • Like
Reactions: Molitor
Yeah I did but I'm not gonna lie I could have done it alittle better. It was a pain cleaning off the old one and I was in a rush. Never thought about it. I'll pull it of and replace it Monday. As I recall it was cheap. So it won't hurt nothing and ill be sure to get it real clean. Thanks.+reps
My phone won't let me do rep but ill get ya when I get home tonight lol
spray some carb cleaner on the EGR valve to check for vacuum leaks, a change in idle rpm will tell you there's a leak.
A handheld tuner will tell you nothing and probably fix nothing. Get it on a dyno for a tune.
I don't need the tuner to tell me anything, I bought it to program the computer for the aftermarket parts. I tried the spary thing, no change. no dynos around my area.
when it runs like crap, is it when u first start the car?? then idles smooth after a little bit
Discussion Starter #9
yeah, almost all the time it does it shortly after I first start it after it sits for a bit, I just had the car set back to factory, tomorrow I'm gonna start it and see if it does it again. I already miss my shift tune though, stock shifting feels like poop lol
1 - 9 of 9 Posts
