1 - 20 of 32 Posts
!FACEPLATED!
I modified my shift boot and bezel so whenever the trans has to come out, I done always have to remove the bezel to get the shifter off.
Better than Drugs!
Frankenstein man. Kind of cool. Saves you trouble and doesnt look bad. Nice
!FACEPLATED!
I still have to trip the rear of the trim ring so that it matches up with the bezel a little better
Good idea, my trans has been out so many times I thought about putting a zipper on it. :D
!FACEPLATED!
!FACEPLATED!
Discussion Starter · #10 · (Edited)
Was it really that difficult to take the bezel off? I've taken mine off probably 5 times in the last month for various wiring stuff. And btw, :puke
you can only take them off so many times until the clips finally break off for one. 2 having to take the pistol grip off every time to take the bezel off so the original shift boot can slide off. I will be taking the chrome ring off and mounting the rubber from the underside of the bezel
KCCO
you can only take them off so many times until the clips finally break off for one. 2 having to take the pistol grip off every time to take the bezel off so the original shift boot can slide off. 1.)I will be taking the chrome ring off and 2.) mounting the rubber from the underside of the bezel
1.) Thank god
and
2.) Sounds like that will be much better. Look decent and still suit your original purpose
!FACEPLATED!
Discussion Starter · #13 ·
yeah i was in the middle of working on it and noticed it was time to take my daughter to my parents for pizza night, so it had to get put on hold
!FACEPLATED!
Discussion Starter · #16 ·
cool deal. i dont see why you even bother with anything inside you car anyways :lol
the only reason why i did it was because I lost the lower shift boot and didnt want a big hole in the floor for things to go through, and also to keep things out of the shifter
Good idea, I have the same handle and it sucks taking it off bc the wires for the button get wrapped around the shifter base under the boot while your unscrewing the handle. Btw I have alreay had 1 fire inside my car and don't want another, where did you get the fire extinguisher and how much?
!FACEPLATED!
Discussion Starter · #18 ·
its just a cheap one shot I got off ebay. I will be going with a clean agent extinguisher eventually
Is it that hard to get the bezel off? Mine pops off in seconds. I guess if it works for your and you don't mind how it looks then it's all good.
1 - 20 of 32 Posts
