1 - 20 of 22 Posts
i have been thinking lately, and i just said **** it, i'm gonna throw some nitrous on my car and be done with it. i might do a stroker down the road, wayyy down the road, but that wont be anytime soon.. i'm just gonna run about a 100 shot and be done with it.. here's what i plan on getting, let me know if this sounds about right, and if there's anything else i need to add..
nitrous kit:
Nitrous Oxide Systems (NOS) 05115-IINOS - NOS EFI Nitrous Oxide Systems - summitracing.com
control panel:
Ashtray Sleeper Nitrous Panel (87-93)
purge valve:
Nitrous Oxide Systems (NOS) 16032NOS - NOS Purge Valve Kits - summitracing.com
bottle opener:
Nitrous Oxide Systems (NOS) 16058NOS - NOS Remote Bottle Valves - summitracing.com
automatic pressure controlled bottle heater:
NOS Nitrous Bottle Heater - JEGS
RPM activated window switch:
MSD Ignition Window, RPM Activated Switch, MSD
I didn't look at every link, but don't forget a fuel pressure cut off switch.
got a link for that?
and what about that purge valve i have listed, is that the right hose size? if it isn't how do i know what hose size i need?
nitrous kit:
control panel:
purge valve:
bottle opener:
YOU DONT NEED A DUAL STAGE NITROUS KIT,just get the single stage 05115 kit
what's the difference in a dual stage and single stage kit?
The Razor's Edge
dual would be like 50 in first then 150 in second....two stages....
i think your going a lil over board with all that ****.....open the bottle your self...and save your self 200 bucks....
personally i'd get a zex dry kit and be done with it, you don't need a purge, just turn the switch on just as you are finishing your burnout , i wouldn't buy a remote bottle opener i'd use that money to upgrade your fuel pump and change the fuel filter
remote bottle opener is for keeping the car legal on the streets......so depends on what you're doing with it
Discussion Starter · #11 ·
ok so i need a fuel pressure cut off switch, and a bigger fuel pump too.
and i wont take this car to the track every weekend, MAYBE once a month.. this is pretty much just to play around with on the street occasionally, and whenever i do go to the track.
what size fuel pump should i go with? where can i get a fuel pressure cut off switch? is there anything else i'd need?
Discussion Starter · #13 ·
why?
That's a good pump, get it!
ok thanks ill be needing it in a few months and they have had it listed on their site since ive joined this forum, "im a cheapass but only when thats ok!!!"
Discussion Starter · #18 ·
ERROR
This product was not found in our database. This product has been removed or is not available on our website. Please call 1-800-MUSTANG for more information
great
1 - 20 of 22 Posts
