1 - 8 of 8 Posts
Hi,
Where can I get a Stock 2003 GT MAF sensor?
AmericanMuscle wants $189, which im not paying, and I don't think it is stock. My friggin check engine light came back on and my car's RPMS were sputtering. The last time it did this I cleaned the MAF (since it pulled that code on the scanner) and my car was smooth as can be. This time I cleaned it again and it's not working...
Thanks,
Check out Tousley Ford. Does the MAF appear to be damaged?
No and this is really pissing me off. Car pulled this about a month ago and threw codes for Fuel Rail pressure sensor and MAF. I went right to the MAF and cleaned with carb cleaner, let it dry, plugged it back in and viola...car worked perfect.
Check engine light comes back on now and car is experiencing same symptoms as before with the sputtering RPM's and low power.
Have you checked the codes? If so what are they?
Forgot. Whatever the fuel rail pressure sensor is & MAF low circuit.
I have them in another post from the last time this ocurred. i'll dig them up on my train ride home and paste in here.
Thanks
As promised here are the codes from last read:
P0190 Fuel rail pressure sensor low input
P0102 MAF or VAF circuit low input
P1237 (This said pending on the computer scanner?)
P1132 (This said pending on the computer scanner?)
P1152 (This said pending on the computer scanner?)
Last month when it did this I took out the MAF, cleaned it, and the car ran beautifully. The RPMs went back to normal and the car was not starving for gas.
Fixing the MAF took away all the other codes too after I reset the CPU.
1 - 8 of 8 Posts
