1 - 7 of 7 Posts
my check engine light is coming on and i check it with my SCT tuner from AM and it says it my MAF code=p1100. i cleaned it off once by blowing on it. then the engine light went off for about 100 miles...what should i do?
Try replacing your MAF? If it keeps throwing a MAF code, then start there. It could be other things, but that would be my first attempt.
:yes
Possible Causes
Poor continuity through the MAF sensor connectors.
Poor continuity through the MAF sensor harness.
Intermittent open or short inside the MAF sensor
Google is your friend.
:yes
Possible Causes
Yes it said it was intermittent
1 - 7 of 7 Posts
