1 - 15 of 15 Posts
ok i have my 2001 mustang all torn apart its originally a 3.8 auto stang but i have a 4.2 swap already done but before i slap it all in i want to swap my stang to stick i have a really good deal on a 1997 mustang that is a 3.8 stick shift and i was wondering if i could use that trans with my swap im still searching for some info so any help is appreciated.
That should be the same trans. Its a T5 (i believe world class) which is what the v6 mustangs use. You'll need a bunch of parts including but not limited to:
Transmission
Shifter/Console adapter
Bellhousing
Flywheel
Clutch
Clutch Fork
Clutch Cable
Brake/Clutch Assembly pedals
Clutch cable quadrant
I believe you need the computer that came from the mustang you got the trans from
should be the same drive shaft
Trans cross member
I think that's most of the stuff. There are some T5's that you have to worry about the input shaft length being slightly shorter, but I believe that was on the foxbody 5.0's. If you are pulling from a six it should be fine.
i understand what your saying and just checked up on some parts the part numbers are different for the clutch kits as well as the clutch cable
MOAR BOOST
Just did the swap....you need the above listed items, and you need them for your year car.
There are a few differences between the 94-98 v6 t5s and the 99-04. The speed sensor being the main difference.
Also, make sure you get the correct wiring harness...I got the wrong one and now my car is still on stands until I can find one lol
Discussion Starter · #11 ·
do it so far everything has been plug and play cant wait to find a trans swap and put it all together and get it on the street
I did my trans swap last year in my 95 from auto to a t5, i got lucky and found a seller, selling every part i needed definately best mod i have done so far. Pretty straight foward swap. What kinda trans you swapping? Keep updating love to hear how it goes.
Sent from my MB865 using AutoGuide.Com Free App
The 4.2 from an f150 will need an 01-04 flexplate. If you do the manual swap make that an 01-04 flywheel. Someone had a decent list earlier however they didnt mention you will need to change your driveshaft as well.
Sent from my SGH-T989 using AutoGuide.Com Free App
Discussion Starter · #15 ·
yeah after searching and long hours of calling around junkyards dealers and things like that I've decided to keep it auto until i can get a donor car that way ill be sure i have everything i need and thanks Matt for the info i am aware of the info for the flex plate/ flywheel and the drive shaft was in question but that cleared it all up lol
1 - 15 of 15 Posts
