1 - 11 of 11 Posts
Hi im in the process of putting a 97 mark 8 motor in my gt now im having a problem doing the cop. I was told if i use the valve covers off a 96-98 Cobra i can keep my coil packs and wire it exactly the same, does anyone know if this is true?
Procrastinator
Not 100% sure about the mark viii, but if you are using the mark coils you need to switch the wires on the plug around.
well im going to be using the gt harness which is setup for that
coill packs are used on 99 and up engines
coils are on 98 and earlier engines
The term is "waste spark"
will you be using an ignition with two coils or 8 coil packs?
**** my bad lol two coils. But i couldve swore that was coil packs i thought 99 and up used cop.
oh are they okok cool well will 98 valve covers work for my two coils
1 - 11 of 11 Posts
