1 - 3 of 3 Posts
i am installing my mm k member kit on my 01 gt, need some help on the set up of the coil overs spacers. it say for lowered 2" one small spacer bottom and one small and two large spacers on top. for stock 2 large spacers and one small on the bottom and one small on top. mine is lowered 2" should i just set it up as a stock? because it looks like the tires might rub if i set it up on the 2" drop.
You'll have to play with it. It took me a few attempts to get it right. Make sure you check the shock to hood clearance as well.
1 - 3 of 3 Posts
