1 - 13 of 13 Posts
MGW
I didn't think it was too bad a job, but I did have the car on a lift. The instructions on the DVD are pretty great, if you take your time, it isn't a bad job at all.
The Despised Vert
I just put mine in last weekend.... be careful of the spot weld points above the drive shaft.... they are sharp as a tac... I just jacked the front of the car up and put it on jack stands... plenty of room... Had the dvd in my laptop under the car and it was spot on. I would say it was easy... I didn't have the racheting box end 10mm and that would have made it even easier...Good luck.. and you will love the shifter... I set mine to 5 turns
+1
Did mine on jack stands as well. Wasn't bad at all. Got mine set to 10 turns . . . instructions say that 12 is the max . . . but there was some text on the actual shifting mechanism that said that 10 was the max . . . I stuck with 10 to be on the safe side.
You will love this shifter.
1 - 13 of 13 Posts
