1 - 20 of 20 Posts
i understand fully that a 4.6 is a 4.6
but does that mean that a 4.6 from the gen 5 will fit in my 02?
would i have to buy the gen 5 motor mounts or the 99-04 mounts?
i think the mounts are different but im not completely sure, but your probably going to have fitment issues because the intake manafold it higher than the 99- 04.
BYAHHHH!
u will then need a new tranny with that...or atleat flywheel
!FACEPLATED!
The compression is going to be lower in that one because its for supercharged applications. what are you looking to do? do you have a car with a blown engine?
im planning to swap to one of these or possibly a different one if someone can show me a cheaper, better one but i do plan to get a new tranny but i dont wanna go to a 5.4 because i dont want to have to replace the rear axle and i dont wan to do a suspension kit yet till after i get the motor
i ran a 5.4 for a little bit and never broke my 7.5'' im back down to a 4.6 now and looking to trade everything and go back to a 3.8 so no you dont hvae to swap out. unless yout gonna be stupid and trying to break it
Once the tires are spinning you are fine. Its that sudden force it gets from the hard launches and hard shifting. The 7.5 won't even hold up behing the 5.0 pushrod for very long if it is abused. Sure, granny shift and take off slow or slip the clutch and you will be fine.
1 - 20 of 20 Posts
