1 - 20 of 20 Posts
I bought the MIL eliminators but the plug for the O2 sensor has 2 notches that wont align with the eliminators, can i just cut these things off or grind them down?
Boost gets you laid
grind them down.. my o2 extensions i had to do the same thing. they work just fine i just used a file.
:withhomo
ya they suck. i spent 70 bucks on them and they didnt even work
The plug in ones didn't work worth **** for me. Splice in ones worked.
It's easy to make your own using the instruction from the internet. I did not use the circuit board stuff though. Just used the resistors and capacitors, some heat shrink tubing, and a little black electrical tape to help reinforce it some.
Looks like AM ripped of my design (from 2004), right down to the heat shrink tubing--more power to 'em!!!
You can make your own, a pair, for less than $5 (Harbor Freight has heat shrink tubing assortment for $1.99)--while you are there get a decent crimper--they have a full compression ratcheting crimper for $9.99, I've had one for 5+ years and used it A LOT!
Then go by your FLAPS and get some dielectric grease to fill the butt splices with before you crimp them.
Fill the splices with the grease, then insert the wires from both ends so that they mingle and overlap in the splice--then use the compression crimper, you will never have a problem with that connection.
Crimp connection problems arise when you do not use dielectric grease, do not mingle and overlap the wires (or worse crimp each separately, and worst of all using one of the el-cheapo "squashing" style crimpers...
MILS don't always work 50/50 is the work or not but i hear the homemad ones are more likely to work then the ones premade
Baker Jr.
Splice in work, end of story, 17.99 in american muscle section. wire it right and it will work or get a sct tuner
what that sexy bitch said ^
1 - 20 of 20 Posts
