1 - 7 of 7 Posts
Today I was driving home from the DFW area, and it was raining. I would be cruising at 70 or so and then all of the sudden out of nowhere my car would miss briefly, and then go back to driving normal. I do have the JLT CAI, I was wondering if moisture might have been causing this? It happened more frequent during heavy rain.
N/A 4v Guru
Have you checked the filter to see if its wet after this happens?
If it isnt the water issue, I'd replace the plugs... I had a slight miss in low rpm range and I changed the plugs and its running great now. If it is the water, i'd either seal the hood more where it latches, or try and find a way to keep water from getting down in the plug hole,
1 - 7 of 7 Posts
