I have a 1991 5.0 LX Hatch and it is stock except for 3.73s and exhaust and I want make it handle awesome for Weekend driving and eventually some Autocross next summer. I was thinking about buying this kit to install over the winter and as I looked through the parts I noticed there are no upc's.
1990-93 Mustang Road & Track Box includes
* MM Road & Track Springs
* MM Caster/Camber Plates (select Black or Chrome finish option)
* Bilstein struts
* Bilstein shocks
* Front and rear Urethane Spring Isolators
* Urethane Pinion Snubber (solid axle Mustangs)
* MM XL Series Full-length Subframe Connectors
* MM Strut Tower Brace
* MM 4-Point K-Member Brace
* MM Panhard Bar with Aluminum Rod
* MM Heavy-duty Rear Lower Control Arms
* MM Solid Steering Shaft
* MM Solid Steering rack Bushings
* Front Swaybar bushings
* Front Swaybar end links
* Front control arm bushings, urethane
Is this because you do not need them or are you supposed to keep the stock ones or what? I would like to hit the drag strip at some point, not often but maybe once or twice a summer, any suggestions? Will this also be a night and day difference in my fox? Thanks in advance for any input anyone can provide.
* Bilstein struts
* Bilstein shocks
