1 - 4 of 4 Posts
Was going to replace the stock ones with the urethane ones but also found solid motor mounts.... What is the difference??....
go urethane, you still need a little flex in your drive train or you will start breaking stuff...the only reason you would need solids is if you had a tube car with a cage and a built rearend, 31 spline axles and slicks that could handle that force.
1 - 4 of 4 Posts
