1 - 10 of 10 Posts
is there any fabricating needed to use these? i have to put a spacer on my intake to clear my valve covers but i will need a cowl hood.. will these drop it enough to avoid having to get a new hood? i want to keep the sleeper look..
ive heard that convertable mounts lower the motor
What size spacer are you using? I used a 1" on my engine build and I have a convertible mounts and the original hood still won't fit. I'm in the same boat you are, looking for a hood to fit. Thinking about getting the Cervinis 2.5" cowl hood. Just thought I'd let you know
i am not sure what size spacer i need.. i gave the explorer intake and its proly gonna need a 1"spacer
how much do the drop mounts lower it? if i can get 1 " lower it might work..
Just a suggestion, but wouldn't it be easier to just get a different set of valve covers? You can get the stock ones polished or chromed or powdercoated.
or get a tubular Kmember.....i know this is one of the more expensive options but i know of 351W's fitting under a stock hood with the right Kmember
i have a set of stock ones that look nice i painted them silver but i want to use the nice shiny ones..lol
yeah those do look good.......but if it comes down to it just to get the car on the road you might use the stock ones for a while till you get money for the hood.....its only a couple hours to remove the upper intake and replace valve covers sometime
1 - 10 of 10 Posts
