1 - 7 of 7 Posts
What's up guys new to the forum . Need some help on a motor swap , looking for a 4v motor (swap is for a 2002 mustang gt ) . Does anyone know where I could get one cost and parts needed to do the swap .any web sites or salvage yard where I could check for the donor motor. Thank you Josh from guam
Better than Drugs!
the block on the aviator is the same as the cobra or everything minus the intake? (view sig on why I ask lol)
Procrastinator
its an aluminum block, not the same as the one in the 96-98 cobra but its not a bad block. Its a C head motor so your B head intake wont work on it. Thats ok though, C heads make better power than Bs and the intakes can be found fairly cheap.
motor swap
Thank you for all the info .... But in the mean time if anyone finds a motor and harness please let me know the price . Thank you again josh
King Trashmouth
4v motors you can use:
B-head: 96-98 Cobra, Lincoln MKVIII
C-head: Mach 1, 99-04 Cobra, Mercury Marauder, Lincoln Aviator.
Note: 99-01 Lincoln Continental's are 4v's, but configured for FWD, do not use them. You can scavenge the heads and timing system from them if need be.
If you're just looking for a 4v swap get a MKVIII motor. I've seen them go for as little as $500 at junkyards. Also see the MKVIII engine swap thread.
1 - 7 of 7 Posts
