41 - 53 of 53 Posts
Discussion Starter #41
Not sure. There are a lot of quirks in the electrical system of these cars and the hotter it gets the more restrictive it is to pass the current. Kinda like when you heat up a magnet enough, it is no longer magnetic until it cools down.
Yeah i wasn't sure if resistance was building up somewhere or just breaking down.
That ticking noise does not sound good at all. Do you know how hot your engine is because your needle looks dead.
It hasnt died yet and done that.I have autometer pro-comp gauges in the center air vents and below. We unhooked the stock gauge..
My buddy jeff who works at SVT and owns a speed shop thinks it might be the aftermarket IAC..
Mines been doing this too.
Also my fan hasn't been kicking on, which is why I took it to my shop to see why my 94 was running so hot; well long story short he said the ECM (control module) was going out.
Not sure if this is the problem or not since I haven't replaced mine but just wanted to throw that out there in case it may be the problem..
If you find out what it is, let me know!
Discussion Starter #43
I'm not sure if that's it. I've been driving it no problem on short trips 20-30 min and its been fine. I drove it around a good bit today though and on the way home while in gear it did the sputtering jerking thing really fast like it was missing for 2 seconds and then was fine. Then about a minute later still cruising it lost power for a slit second maybe less and was ok, like i was still in the gas but it was like i took my foot off the gas kind of feeling.
I came to a stop a little bit up the road and it started surging like CRAZY from 300-400-rpm to like 1400ish and then eventually dipped so low it shut off. I waited 5 seconds and started it up again no problem but it immediately started surging badly again and eventually shut itself off again while waiting at the light.
Discussion Starter #46
have you checked 02 sensors
02 sensors are brand spankin new.
my cobra used to do the exact same thing, replaced the coil and it was good as new.
funny you should say that.. I just came in not 5 secs ago from my garage and replaced the coil out. I'll see what she does in the morning! Frankly i've narrowed it down to the last possible things. Praying to god this does it seemingly if its happened to you too. :3gears
Discussion Starter #47 (Edited)
Swapping the coil didn't work.
While driving it literally shut off while in gear and barely in the gas. The tach went top zero and i could hear the motor barely running. I put it into neutral and it died immediately.
I noticed this morning when i went to start the car the voltage was below 12 volts. It still started but the voltage instead of being above 14 volts like it always is, it was around 13.5 and going down somewhat. Also when i started it this morning, as soon i went to turn the key to start it, instead of the starter normally taking like 1-2 secs turn it on like any other car it was almost instantaneous of me turning the key and it starting, went up to about 1800 and then fell down rapidly to about 400-300rpm trying to stay running but then shut itself off. Its been doing this on cold start-up only. After its stays running and i restart it the second time it runs fine until after i run it for awhile and then it does that shaking sputtering warning sign for 2 secs and then eventually dies.
HELP!
1NVERTED5.0 I know this is a REALLY old post but what ended up fixing your problems? I am having the same issues and have swapped about everything to this point. MAF and IAC next.
41 - 53 of 53 Posts
