Anybody out there got any homemade mods you did on your own, stemming from your own creativity, and beaming with the passion that is the mustang?
looks like its not quite flush and would be a pain with your arm on it (probably would burn your arm alittle in a az summer hereMy DIY Projects:
^^ Controls red interior lighting i installed
^^ Metal emblem i got at a swap meet looks off center but its not
Yea its flush now i remove some more padding underneath sits there quite well.looks like its not quite flush and would be a pain with your arm on it (probably would burn your arm alittle in a az summer here)
I believe in the center console the switch for the automatic shifter lighting is in manual and auto cars. I looked in mine and saw it. You can wire lights into this switch and they come on when you have the dome lights on or the dash lights. As long as you aim them right they shouldnt be a problem. I have 4 lights I bought for pretty cheap on ebay but I might not do them. Possibly under the drivers and passenger seats just for a little effect but thats it.07 Boss - sweet stuff you have done there!!! Do you have any electrical diagrams that you used for the engine cooling switches or can explain how you went about doing it??
dalton2021, do you have the interior lighting coming on with just the switch? or with the dome lights also?
I am working on a the same thing with blue LED lights in the foot-wells, so they will come on with the dome lights when you open the doors and with an additional switch where they will fade on and fade off. Hopefully I will find time to finish this by May and when I do Ill post some pics...
Where did you find lighted sill plates?No diagrams. Basically I used a fuse wire from the battery to the switch in the middle. from there I ran it through each of the other switchs and ran one to the relay on my electric water pump and the other to the high speed fan motor (I think it was green and violet, down by the harness that runs to the fan behind the passenger headlight area. But I will have to actually go out and look at it to be sure).
As far ar the lighting I have mine hooked up piggy back style from my lighted sill plates. They come on as all the other interior lighting, either with the door open or the dimmer switch. My lighted sill plates are wired to the dome lights via wires in the passenger A-pillar. Positive goes to the black/lt blue wire and ground goes to the yellow/green wire.
