1 - 11 of 11 Posts
My 1999 Mustang coupe is having problems starting Web the engine is cold I replaced spark plugs changed oil don't know what it could be it will start Web the engine has ran for a little while but Web it sits for a crow hours and gets cold again it won't start easly keeps draining batterie trying to start it :( any suggestions of what it could be
PSN alphadong11
Does the battery sound weak on cold days, but on warmer days ~40 degrees sounds fine? If so you may need a battery with more cold cranking amps. On cold days, when you go to start it turn off all accessories, close your door so the door chime won't be going off, turn off the blower/heat and the radio and see if that works for the time being.
PSN alphadong11
What cranking amps did you replace it with? What was the viscosity of the oil? What were the plugs gaped at?
650 THIS IS A STOCK MUSTANG NOTHING ADDED NOTHING REMOVED THE BESIDES SPARK PLUGS AND BATTERIE TRIED THE FUSES THE ARE ALL GOOD
1 - 11 of 11 Posts
