1 - 18 of 18 Posts
Mustang Lighting Experts
Mustang HID Conversion Kits
Diode Dynamics is pleased to announce the new Premium Diode Dynamics HID Conversion Kit. This kit has been carefully designed from the ground up to be the highest-quality HID kit available on the market, without exception.
Ballast: The ballasts are the most important component of an HID kit, as they provide the power. After years of providing midrange and high-quality ballasts for vehicles of all makes and models, Diode Dynamics learned what was important in making a good ballast, and applied it when designing these.
Controller Chip. Most digital (DSP) ballasts on the market still use generic chips, which are cheap, and work pretty well. However, when you need maximum quality, you need a new computer chip designed for one purpose. This is known as an Application-Specific Integrated Circuit (ASIC). These ballasts use brand new DSP ASIC chips for maximum efficiency and brightness, fast warmup time, and extremely stable operation.
CAN-BUS. Some vehicles have systems which sense the power consumption. Since HIDs use less power than factory halogen bulbs, this can cause issues. You can resolve this by adding capacitors, known as warning cancellers, or some ballasts come with them built-in. However, sometimes that's still not enough to trick the vehicle! To fix it, this ballast has not one, but two CAN-BUS modules, which provide capacitance and resistance to the circuit to defeat even the most troublesome modern CANBUS systems. Even if your vehicle does not use a CAN-BUS system, these modules will provide extra power smoothing for reliable operation. Simply put, this ballast will work on any vehicle, the first time you plug it in. With this kit, you don't need to worry about capacitors, warning cancellers, or resistors.
Igniter and Startup. You may have heard of ignition issues with other ballasts, caused by an igniter that is too small to withstand cold temperatures. No reason to worry with these ballasts- the oversized 24kV external igniter means that you will never have an ignition issue, even in the coldest temperatures. Additionally, the ASIC chip in these ballasts means that you only need 4 amps at nominal voltage to start up. These ballasts consume less power than any other on the market, meaning 100% reliable and fast startups, every time.
Shielding. Ever noticed a little black plastic thing clipped onto your laptop charger cord? That's a ferrite bead, which is used to suppress high-frequency signals, which can create radio interference. All ballasts generate these signals, and most just have protection in the ballast. We've also included ferrite beads on the wire, to suppress them.
LED Indicator. Convenience is key, especially during installation. To make things easy, we've added an indicator LED on the input wire, so you know that the ballast is getting power.
Case. These ballasts are the smallest you will find, about the size of a pack of playing cards. The case is fully potted, or filled with epoxy, which makes them fully waterproof and shockproof. Most ballasts on the market are filled to some degree, but these are completely filled to the top, sparing no expense to ensure longevity.
Bulbs:
The bulbs included with Diode Dynamics kits are CNLight bulbs. CNLight is the top manufacturer of aftermarket bulbs in the world, providing the best quality available. You might see other high-quality kits on the market which also use CNLight bulbs. They provide superior life, brightness, and color attenuation when compared to generic HID bulbs, like those found in most cheaper kits on the market. The one-piece base design prevents any issues with separation over time, making the entire bulb extremely reliable.
The CNLight bulb temperatures are rated accurately in Kelvin temperature at 35W, and have an industry-standard 3000 hours of estimated bulb life, which should outlast your vehicle. Please be aware that most HID bulbs are rated inaccurately from other manufacturers. 8000K is not dark blue, and 6000K is not pure white! We provide accurately-measured colors. 3000K is our lowest temperature, and has a pure yellow output, which is great for use in fog lights. 4300K is a pure white output, as seen on many factory HIDs. It will not have any blue tint to its color, and might appear slightly warm. 6000K is our most popular color, which produces an ice white color. It has a very slight hint of blue, and matches best with most LEDs. 8000K is our highest temperature, which produces an ice blue color. This is not a strong blue color though- it is still primarily white, meaning there will be no decrease in light output.
Relay:
Your Premium CAN-BUS HID Kit includes a brand new Heavy-Duty HID Relay, to power your HIDs directly from the battery, instead of the factory wiring. This relay has been designed from scratch, and utilizes a fully-sealed, waterproof relay, with flyback diode, and even has a built-in capacitor for input power smoothing. All wires are sleeved with braided techflex for an attractive appearance and extra protection. The input wires are each a meter long, and the output wires are one meter and two meters, which means the wiring will be long enough for even the biggest vehicles. The single-ground design makes installation easy. This relay was designed with reliability, convenience, and long-life in mind.
Warranty: Our warranty is through Diode Dynamics, LLC, so you can be assured that you will get fast and friendly service should you have any problems. There is a 3-year limited warranty on all HID Kit components, including HID Bulbs, Ballasts and Relay.
Shipment: We carry our own inventory, so no waiting for them to be shipped from overseas, or waiting on big, unreliable suppliers to ship them. They ship right from our own inventory, in St. Louis, Missouri, usually the same day you order.
Kit comes with:
  • One pair HID bulbs in your choice of bulb size and color
  • Two 35w super-slim ballasts
  • Mounting hardware for ballasts
  • Limited Lifetime warranty on electronics (ballasts and wiring)
  • 3-year limited warranty on all components
  • Free Diode Dynamics decal
  • Diode Dynamics 30-day satisfaction guarantee
  • Heavy-duty HID Relay Harness to protect your factory electronics.
Click To Order Mustang HID Kit:
1994-2004
2005-2012
1994-2004 Fog Lights
2005-2009 H10 Fog Lights
2008-2014 Fog Lights
If you have any questions, please don't hesitate to post, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Customer Submitted Photos:
Customer Reviews:
"Purchased the "1994-2004 Ford Mustang Hi/Lo Beam HID Conversion Kit" with the RELAY + 9007 BiXenon. Everything was plug and play. Luckily I had a friend who had done this a few weeks ago and helped me.
Placed on the passenger side is the harness end with the Ballast, Relay, High beam and Ground connector, while driver's side is where the Ground connector plus the single Power cable (RED) that connects to the positive cable on the battery. The rest of the connectors are fool proof and plug n play.
Install took about 30 minutes due to routing of the harness so that it was clean looking and hidden as much as possible.
Definitely will recommend to friends and family."
(Posted on 2/18/13)
"By Far these are the best of the best. I have been through many HID Kits for the mustangs that i have owned and these are the best aftermarket HID kit that I have seen!!!!!!!!
Thanks,"
(Posted on 12/20/13)
"Just installed my bi xenon 6000k kit and what great quality. Right out of the box you know you don't have some cheap knockoff. Everything plugged together perfectly, harness was JUST the right length. The hi/low option works great and really lights up the way. Completely satisfied from ordering, shipping time, and finished product" (Posted on 12/17/13)
Are these kits high and low hid?
Yes! That is correct!
We offer the H13 kits with BiXenon (HID high and low beam) AND the Halogen Hi option (HID low Halogen high)
I installed the H13 Halogen Hi beam kit on mine. I don't really need an HID high beam because my low beams are perfect for all night time driving situations
Let me know if you need more information
Thanks!
Nick C.
Glad you posted this. I was planning on buying hi/low/fogs conversion kits somewhere else but this seems like the better deal. Ill purchase within the next couple months!
Sent from AutoGuide.com App
Discussion Starter #9
We've seen plenty of designs for the LED headlight kits and none of them are a viable option at this point in time. The cooling fans that most of them require are mechanical and fail easily within 1 year.
Additionally, most of the LED headlight kits on the market promote ridiculous lumen ratings, but those are actually output estimations under perfection conditions (no heat) at maximum power, which is completely unrealistic. They also don't utilize housings properly either, so the patterns aren't consistent.
HIDs provide better usable light output and are still more reliable. We are still working on our own LED designs for feasible headlight replacements
Nick C.
I will PM you, but I will post my question here as well for others;
I would love to get HIDs into my 2010 GT Premium Convertible. I saw some a setup on ebay that fit the 2010 GT, but not the premium model.
In addition to these ballasts and bulbs that are shown at the top, I beleice I need a whole new headlight assembly to insure the light is proected out correctly. Do you, or does anyone else, know a place to get those as well?
It is my impression tha a proper HID system has a very distinct cutoff line for the light as it projected out to keep the light down and onto the road. A factory headlight will not provide this with an aftermarket HID bulb only.
Discussion Starter #11
Thanks for sending me the PM. I sent you a response with more information about our HID conversion kit.
You won't need to replace anything in order for this kit to work properly in your headlight housing. Our kit will not create excessive glare or be unsafe for other drivers
Thanks!
Nick C.
do you guys still have any of the slim discontinued kits available for a lower price? im fine if they aren't covered by warranty or anything
Discussion Starter #18
Our Memorial Day sale starts NOW! Today through Friday, 5/29/2020, save 20% on all lighting upgrades, including our HID Conversion Kits and Replacement HID Bulbs by entering coupon code "USA20" at checkout!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 5/29/2020. Cannot be combined with other coupon codes.
1 - 18 of 18 Posts
