1 - 13 of 13 Posts
Mustang Specification's
1999
Base Coupe- 73,180
Base Convertible- 19,299
GT Coupe- 19,634
GT Convertible- 13,699
Cobra Coupe- 4,040
Cobra Convertible-4,055
Total133,637
2000
Black - 24,360 (1,818 Bullitts)
Dark Highland Green -3,041 (Bullitt only)
Electric Green -2,793
Laser Tint Red - 23,740
Mineral Grey -17,068
Oxford White -17,689
Silver -23,119
Performance Red - 9,775
Tropic Green - 7,913
True Blue - 15,361
Zinc Yellow - 10,706
Total - 155,563
Engines-
3.8L 232ci V-6 190 hp @ 5250 rpm 220 tq @2750 rpm
4.6L 281ci SOHC V-8 260 hp @5250 rpm 302 tq @4000 rpm
4.6L 281ci DOHC V-8 316 hp 316 tq (Cobra)
2 valves
Performance -
V-6 - 0-60 8.6 sec, 1/4 mile 16.5 sec
GT 0-60 5.5 sec, 1/4 mile 14.1 sec
Cobra 0-60 5.4 sec, 1/4 mile 13.9 sec
Drivetrain -
8.8" Rear GT
V-6 7.5" Rear
V-6, GT -t45 transmission 5spd, Solid axle, 3.27 ratio
Cobra- IRS, 3.27 ratio, t45 Transmission, 11" clutch
V-6 5spd - T50OD Tranny
4R70W 4 speed automatic transmission
99-00 windsor motor, 13/14 valve cover bolts, 8 bolt crank
01-04 romeo motor, 11 valve cover bolts, 6 bolt crank
Specs -
Configuration - 90-degree
Compression Ratio - V-6 9.36:1, V-8 9.0:1
Bore and Stroke - V-6 3.81 x 3.39, V-8 3.55 x 3.54
Combustion Chamber - V-6 61.5-64.5 cc, V-8 43.9 +/- 1.5 cc
Intake Valve Diam. V-6 1.86, in V-8 1.75-1.76 in
Exhaust Valve Diam. V-6 1.46 in, V-8 1.41-1.43 in
Oil Pressure - Hot V-6 40-125 psi @ 2500 rpm, V-8 20-45 psi @ 1500 rpm
Ignition System - V-6 EDIS V-8 Coil on Plug
Spark Plug Gap -0.052-0.056 in
Firing Order - V-6 1-4-2-5-3-6 V-8 1-3-7-2-6-5-4-8
Cast Iron Blocks
Brakes -
Front Rotors 10.8"
Rear Rotors 10.5"
Weight -
V-6 coupe 3064 lbs
V-6 conv. 3203 lbs
V-8 Coupe 3237 lbs
V-8 Conv. 3375 lbs
Capacities -
Fuel 15.7 Gal
Oil 5.0 Qt's
Coolant V-6 11.8 Qts V-8 14.1 Qts
Manul Tranny Fluid -V-6 5.6 pints V-8 6.6 pints
Automatic Tranny Fluid - V-6 13.9 Qts V-8 12.8 Qts
Rear axle - 7.5" 3.25 Pints 8.8" 3.75 pints
2001 Bullitt
723 true blue
1,818 black
3,041 dark highland green
Total production 5,582
Engine-
4.6L SOHC V-8 approx 270 hp @ 5000 rpm
Approx. 315 tq @ 4000 rpm
Twin 57mm TB
Brakes-
4 wheel Brembo
13 in front
11.7 in rear
Suspension-
3/4 in lower than GT
Tokico struts and shocks
Front and rear stabilizer bars
Fraim rail connectors
Weight-
3254 lbs
Compression-
9:4:1
2001-2004 Mustang Difference
Early 01 t45 5spd transmission 8 bolt cranks (Production date ending 01/01)
New water pump pulley, 99- mid 01 had longer shaft
Late 01 TR3650 5spd Transmission 6 bolt cranks
Pulley designed changed to shorter shaft, change in pump pulley
2003-2004 Mach 1
Engine-
4.6L DOHC 281 V-8 32v
305 hp @ 5,800 rpm
320 tq at 4,200
57mm twin TB
Aluminum block
4 valve
Drivetrain-
Solid axle
3.55 Gear ratio
TR3650 5spd transmission
AOD-E auto
Compression-
10:1:1
Brakes-
Brembo 13" front, 11.7" rear
Weight- 3465 lbs 5spd, 3475 auto
Suspension-
Tokico Shocks/struts
Subframe connectors
Modified Macpherson strut
Production number's-
2003 mach: Total - 9,652
5spd - 7709
auto - 1943
Black - 1611
Dark Shadow Gray - 1595
Zinc Yellow - 869
Azure Blue - 2250
Torch Red - 2513
Oxford White - 814
2004 mach: total - 7,182
Torch Red - 1259
Azure Blue - 1316
Black - 1064
Dark Shadow Gray - 1039
Oxford White - 697
Screming Yellow -768
Comp. Orange - 1039
2003-2004 Change
03 black valve cover's, 04 CObra silver valve covers
04 40th ann. badges
04 Screaming yellow (replaces zinc) and competition orange
2003-2004 Cobra
Engine
4.6L V-8 DOHC 32v s/c
390 hp @ 6,000 rpm
390 tq @ 3,500 rpm
4 valve
Compression 8:5:1
0-60 4.5 sec
1/4 mile 12.9 @ 111mph
Configuration-
Cast iron block
aluminum heads
counterweighted forged crankshaft
Eaton generation IV Roots-Type supercharger
water to air intercooler
Twin 57mm TB
Drivetrain-
8.8" IRS
3.55 gear ratio
Aluminum driveshaft
31 spline
11" single plate clutch
T56 6 speed Transmission
Brakes-
Vented Brembo
13" Front
11.7" rear
Weight-
Coupe- 3,665 lbs
Convertible- 3,780 lbs
2003 Production
Black - Coupe- 2,251 Conv. 1,679
Torch Red - Coupe 638 Conv. 582
White - Coupe 621 Conv. 308
Satin Silver- Coupe 242 Conv. 81
Silver Metalic- Coupe 992 Conv. 548
Redfire- Coupe 955 Conv. 610
Sonic Blue- Coupe 1052 Conv. 355
Zinc Yellow- Coupe 490 Conv. 319
Dark Shadow Grey- Coupe 851 Conv. 446
Mineral Grey- Coupe 302 Conv. 154
Total- 13,776
2004 Production
Black - Coupe 820 Conv. 392
Torch Red - Coupe 477 Conv. 167
White - Coupe 316 Conv. 128
Mystic - Coupe 515 Conv. 495
Silver Metallic - Coupe 551 Conv. 256
Redfire - Coupe 509 Conv. 209
Competition Orange - Coupe 281 Conv. 72
Screaming Yellow - Coupe 299 Conv. 167
Total 5,664
2003-2004 Difference
Screamign yellow, Competition orange, Mystic Chrome
Exhaust Work with Catylitic Converters to improve fuel economy
Discussion Starter #2
Not much more to do when you just get out of the hospital so I have nothing to do but sit here, im sure i left a whole lot out and have something wrong but o well, I didnt realize i was writing in smaller font sorry, if an editor could make it bigger, anyway enjoy.
hah guess that was pointless
bno it wasnt pointless. I liked it.
I have to disagree with the 99-01 cobra 0-60 and quarter htough.
I could be wrong, I havent checked, but I dont htink a car with 70 more hp thatn a gt is only going to run .1 faster 0-60 and .2 faster in the quarter...
99 to 01 cobras tend to run 13.4ish, at least from what ive seen in person, was i wrong or didnt i see the 0-60 and 1/4 times for the mach
I didnt put any up because so much contraversy over it, site's say 0-60 in 4.7 1/4 in 13.2, so people might argue it wont run a 13.2, i believe they do.
Muscle Mustangs & fast fords took a bone stock mach 1 to the track, ran a 13.13 @ 105.5 mph, 2.07 60 ft.
machs do run low 13s, ive seen one do it at the track, and ill have numbers when i bring mine to the track, throw some sticky tires on the machs and they can even better times, machs are beast with just,shocks,springs,upper lower control arms,better frame ties if you wish to get better ones,gears,and some drag radials
Discussion Starter #10
Yes, like i said there's plenty left out, just bored and gave me something to do.
clean it up and space it out a little better, make it easier to read and i think it would be a good sticky
Discussion Starter #12
Yea i thought i was typing bigger and thought I had it spaced out better, its real annoying to read like that
1 - 13 of 13 Posts
