1 - 12 of 12 Posts
I have a 1996 Cobra Mustang,the starter clicks. I have checked the battery, replaced the starter and had it bench tested. I checked the starter relay ire thats close to the battery, I took battery cables and jumped them down to the ignition module under the dash.Could it be my anti theft alarm or my clutch pedal position switch??
Just Cheesin'
Need Spark plug help.
Im having a little trouble with my stang.:sorry I put new spark plug wires in it, and now my first bank is running wrong. Im not sure why. all the wires are in the right place. Does anyone have a -good- wiring diagram for a 3.8 with which wire goes to which cylinder?
I would greatly appreciate it. :yes
Hey I have a 1988 mustang with the 5.0 ho and have some work
Done to it and I'm wondering what u should be looking at as
Far as power. I have the stock heads and intakes and lower end
But it has freshened up cylinders new bearings rings etc
Along with a f303 cam I believe it's a very rough idle cam
The ford racing 1.6 roller rockers hydrollic roller lifters a 70mm
Tb and a 1 inch lower intake spacer. It has headman long tube
Headers and a straight through exhaust. However it only has
110 miles on the rebuild so I feel it's not yet broken in yet
But any guesses on whp?
having trouble with my 89 5.0 bored .30 over e303 cam i just put a turbo on it and 42lb injectors with a 255lph fuel pump.. 65mm throtle body edlebrock proformer 5.0 intake.. i am having trouble keeping it running.. i need to get it to run decent so i can take it to get tuned.. it has the a9l ecc in it.. would greatly appritiate some help
1 - 12 of 12 Posts
