1 - 16 of 16 Posts
I'm such a tease, no youtube here.
I'm just sayin everybody should get to experience installing a supercharger and Bassani Race axelbacks at the same time.
PUUUURRRRRRR.....
They drone more than my Bassani Streets. Sound a lot better otherwise. Drone, for now, seems manageable. Much more so than Stingers did a while back (though I did not have headers with my Stingers like I do for my Bassani's).
I will say the muffler hangers on my Race axelbacks suck ass. I've had a half dozen kinds of muffs on this car and these hangers are by far the worst fitting. It is going to take some grinding & cutting on my hanger brackets to keep the hangers from vibrating against them.
Might even resort to cutting the hangers completely off and having them re-welded to fit.
Vids vids vids
Lots of squeaking & rattling to fix first. Here is the culprit.
I have this on each muffler. Believe it or not, after the car warms up muffler shift to the back of the car by 1/8". That hanger which is so close to the bracket then squeaks and rattles against it.
Every other muffler I've had didn't do this. Other hangers angled more away from the braket (from lower left towards upper right in this picture) instead of being mostly vertical right up against the bracket.
This stuff is really hard to bend too. Gonna require a muffler shop that hopefully has a tool to bend 1/4" steel rods. Heck, maybe they'll fabricate a new hanger.
I love this exhaust enough that I swear I'm gonna get this fixed. Looks like an easy fab job to cut this and add some horizontal pieces of 1/4" steel to the top & bottom. In other words, extend the top horizontal part and add a new horizontal member to the bottom.
On the other side of the car I got a air tool cutter thing and removed some of the bracket and it helped...until I discovered the mufflers shift back 1/8" under heat. I wasn't expecting that.
Discussion Starter · #12 ·
Left & right side cats are the same. No diff there.
Got my rattle fixed this morning. The shop put the car on a lift, dood stood under the car with an overhead grip on a 5 lb sledge hammer and....pounded the tip of the hanger a few times and got me a good 1/4" at clearance. No more rattles & squeaks.
With a little persuasion from the fire wrench, you can bend that **** with your pinky.
BTW, vids or ban!
I agree man manipulate that sucker.
Discussion Starter · #16 ·
Damn, not so much fixed.
After a spirited run to test my boost guage, the **** was rubbing again. Not as bad, but still rubbing. I'm gonna have to take this muffler to the woodshed.
1 - 16 of 16 Posts
