1 - 20 of 27 Posts
ok i have recently sent my car in to get my gears installed this may be stupid but can i beat a 99-04 gt? kinda a broad topic i knw there is many variables ... and are pontiac gtps anything to worry about ??thanks
ok with the gears you shouldnt have to worry about a stock 99-04 mustang.....that is if you can drive......as far as the gtps......my mom has an impala SS which has the same motor and i have seen a few run at the track......my car pretty stock and there is one that has the boost cranked up and he runs only about less than a 1/10th of a second faster than me so once again if you get your gears then those shouldnt be a problem
blake did you get master rebuild kit with them too?
yes sir got the ones with the bearings and all
i didnt ask him.....all i know is that he said he had the boost up and i know that on my moms car you can barely hear the supercharger and his was very noticeable
you should not have to worry about either one of those if you have gears
+1
i used to have a 99 with some bolt ons,. and i firmly believe a 5.0w/gears vs 99w/stock gears the 5.0 should take it.. the main reason my 99 felt faster was cuz they come stock with 3.27's, stock 5.0= 3.08's
That adds a little to my confidence thanks is headers a good next mod ?
some guys can drive the piss out of those new edges..i have seen a new edges with just an o/r midpipe in the 13s...
Discussion Starter · #11 ·
and now my confidence is takin away LOLbut my goal is to get under 14 in the quarter haven't been yet
i think gears will put him in the 13s
most foxes came with 273's and yes i believe gears and a good 60ft will get u in the 13's
Discussion Starter · #14 ·
yea i wandered about the 308s cause i knew that 273s were .... but your think that i can get 13s? even with a vert
well i didnt realize it was a vert but still with your better flowing exhaust and the gear and some good driving im sure its possible
guys remember its a vert not a hatch get some slicks pro starts or drag lites gears good driving could get high 13's but it will be harder with a vert
+1000000000 for the subframes makes a completely big difference in the way the car feels and drives..
a stock 5.0 will take a stock new edge anyday..there alot lighter too..and 5.0's also came with 2:73's too not just 3:08s..just get subframes, drag radials, full exhuast and gears then those dip low 13's REAL easy...
well i wouldnt say they are a lot lighter.....maybe 100-200 pounds i think
1 - 20 of 27 Posts
