1 - 4 of 4 Posts
I have an 89 coupe and sometimes when i go to turn on the starter stays cranking when car is on so have to get out and hit solenoid for it to disengage has anyone had this issue if so is there a fix i already replaced, key lock switch, ignition switch and solenoid and starter to :eek:
If you hit the solenoid to fix it, I can only naturally assume you need to replace the solenoid again. Sometimes you get bad parts new.
I have an 89 GT and had this same problem just about a week ago, I changed the ignition switch and solenoid and it doesn't do it anymore, it just takes a long time for it to crank up now hopeing i didn't mess up the starter or fly wheel.
Why not have a Fox?
I had that problem wwith my 93 when i changed my starter. I believe it was because the S wire wasnt connected. Ended up rewiring everthing and works fine ever since. But id change the selinoid again first. I had to get two diff starters before i got one that worked
1 - 4 of 4 Posts
