1 - 8 of 8 Posts
· Registered
At least once a month I end up having to add coolant because the 'Low Coolant' light comes on frequently. I take a look, and the level is below the bottom line on the reservoir tank. I don't see any bleeding out onto my driveway, or any on the engine anywhere...
The car is N/A also.
Other possible sources, help? 93 GT by the way.
· Registered
take off the radiator cap and start is up.. see if there are bubbles in it.. or just pull your plugs and check the condition of them.. coolant leaves a weird white coating. +1 on possible head gaskets.
· Registered
If its not coming out the exhaust or dripping on the driveway it only leaves one other possibility.... Headgasket. :cool:
· Registered
95% head gasket
5% plastic reservoir has a crack and it leaks out when the coolant gets hot.
1 - 8 of 8 Posts
