yup, that was a factory option for Canadian mustangs, the squeaky clutch package...............ya it came like that.
Are you kidding me? DO NOT USE ANYTHING PETROLEM BASED AROUND BRAKE FLUID. If you want your seals to swell in the bore then by all means, lube away! I'd say it would have to be a sqeaky pivot. If any petroleum based fluid mixes with brake fluid in the system, all your seals will swell. Causing your system to possibly stay engaged. You'll be replacing everything.Usually the noise is coming from the inside of the clutch master cylinder. It's the piston making a noise as it's moving through the bore. I haven't looked at mine, but try pushing the pedal in and see if you can look in the bore of the cylinder or maybe the rear end of the piston may be able to be seen. I'd spray some lube in there (between the piston and bore) and pump the pedal a few times to see if it quiets down.
That's what the Ford dealers have been doing. If you lube the bore and any gets inside of the system, then it's leaking anyway. They are using poly seals.Are you kidding me? DO NOT USE ANYTHING PETROLEM BASED AROUND BRAKE FLUID. If you want your seals to swell in the bore then by all means, lube away! I'd say it would have to be a sqeaky pivot. If any petroleum based fluid mixes with brake fluid in the system, all your seals will swell. Causing your system to possibly stay engaged. You'll be replacing everything.
