1 - 10 of 10 Posts
I Just got the cars out for a walk around video real quick and photoshoot with the addition of my new 03 cobra 10th anniversary.
Nice stable, congrats on the 03..
I remember when a bunch of us met up at LVMS in 2013. You brought the Bullitt down, good times!!
I remember that like yesterday. It was fun. This might be your car in the pic, or Jeffs
Oh hell yeah!!! Got my Performance Red GT in there.
Good stuff man, anything done to the Bullitt since?
Yeah, The car is built and supercharged with ported heads and cams. I lost #3 at LVMS at the top of the 1/4 mile due to a lean american muscle tune so It has everything now. I have the mod list saved cuz its easier to post than explain
MMR Street Mod 600 2V/ Brand New Cast Iron 2004 Cobra Block, torque plate bored and honed.
9.5:1 Compression Ratio
Ford Racing Cast Iron Crankshaft rated up to 600HP.
New 4340 5.933 MMR (Modular Mustang Racing) I-beam Rods, these rods are shotpeened, magnafluxed and weight matched.
New Forged Manley lightweight pistons.
Total Seal file fit rings
Clevite Rod and Main bearings.
RAM Powergrip HD Clutch (up to 650 HP).
PRO 5.0 Short Shifter.
Patriot Performance Stage II Heads
Bronze Valve Guides
Viton Valve Seals
Comp Cams XE 270's.
Comp valve springs
BBK Storty Headers.
PYPES O/R X Pipe, no CATS.
SLP catback
Terminator fuel tank
60 lbs FRPP Fuel Injectors.
SCT 90mm MAF.
Mac Cold Air Intake
FRPP throw out bearing
FRPP Aluminum Driveshaft.
Aluminum Radiator.
STEEDA Aluminum Upper & Lower Control Arms.
STEEDA Clutch Quadrant.
STEEDA Firewall Adjuster and Clutch Cable.
STEEDA Caster/Camber Plates.
STEEDA Front Sway Bar.
STEEDA Poly Front Spring Isolators.
Eibach Rear Springs, Offset Rack Bushings, Axle Bump Stops.
TOKICO D-Spec Shocks.
Bilstein Quad Shocks (rear)
Poly Rear Spring Bushhings.
FRPP 4.10 Rear Gears.
Alloy USA Axle shafts
Ford focus duel fuel pumps
Black 304 modifies FPDM
Kenne bell Boost a pump
Tork teck supercharger kit
LED interior lighting
17X10.5 rear wheels with M/T street comp tires
Mach 1 chin spoiler
Mach 1 grill delete
Pillar Gauges (Wideband and boost)
Heat exchanger
Brand new ford OEM coil on plugs
NGK TR6 plugs gapped to .035
MMR 8 quart oil pan
Gates 8 rib supercharger belt
Cobra I/C pump and bracket
SCT Tuner.
Dyno tuned 439/437 RWHP
  • Like
Reactions: x7sage7x
What a dream to own all of those cars. Anyways, how are you liking the Mickey Thompson Street Comp tires? I am currently checking out street tires on 4wheelonline for my 2014 Ford Mustang GT Coupe. There are just too many options, I am looking at Toyo Proxes Sport tires and Nitto NT555 G2 tires.
1 - 10 of 10 Posts
