1 - 11 of 11 Posts
ok so minus a upgraded intake manifold may just use stock this is my planned build to eat ricers plus some cosmetics so I look good doing it. let me know what you think/change about this build:3gears
Performance mods:
SR Performance Blackout Cold Air Intake (99-04 V6)-$99.99
BBK 65mm Throttle Body (01-04 V6)-$259.99
Airaid Poweraid Throttle Body Spacer (99-01 V6)-$114.99
Mishimoto 14in Performance Slim Electric Radiator Fan (79-13 All)-$84.99
NGK Iridium IX Performance Spark Plugs (93-01 Cobra; 96-04 GT, Mach1; 98-04 V6)-$69.99
MSD Super Conductor 8.5mm Spark Plug Wires - Red (01-04 V6)-$74.99
PA Performance Alternator - 130 Amp (01-04 V6)-$259.99
Performance Distributors Screamin Demon Coil (01-04 V6)-$94.99
ProCharger High Output Intercooled Supercharger System (99-04 V6)-$4,299.99
PaceSetter Black Long Tube Headers (01-04 V6)-$204.99
Pypes True Dual Off-Road Exhaust (98-04 V6)-$639.99
Auburn HP Series Limit Slip Differential - 28 Spline 7.5in (79-85 V8; 86-10 V6)-$479.99
Ford Racing 4.10 Gears (99-04 V6)-$179.99
Rear End Installation and Bearing Kit - 7.5in (79-85 V8; 86-10 V6)-$74.99
Ford Racing Aluminum Driveshaft - 28 Spline (79-95 5.0L; 94-04 V6)-$279.99
Street Fighter 4R70W Lockup Torque Converter (96-04 GT, V6)-$797.99
Performance Automatic Street/Strip Shift Kit (01-04 GT, V6, Mach 1)-$79.99
Performance Automatic Street/Strip Valve Body - Auto (01-04 V6, 01-02 GT)-$344.99
Hawk Performance HPS Brake Pads - Front Pair (99-04 GT, V6)-$84.99
Hawk Performance HPS Brake Pads - Rear Pair (94-04 GT, V6)-$69.99
DBA T2 Street Series Slotted Rotors - Front Pair (94-04 GT, V6)-$179.99(pair)
DBA T2 Street Series Slotted Rotors - Rear Pair (94-04 GT, V6)-$179.99(pair)
SCT 4-Bank Eliminator Chip w/ 3 Free Custom Tunes (99-04 V6)-$269.99
Supporting mods:
Eibach Sportline Spring Kit (79-04 V8 Coupe; 99-04 V6 Convertible; Excludes 99-04 Cobra)-$229.99
SR Performance Chrome Strut Tower Brace (94-04 GT, V6)-$119.95
Steeda Rear Shock Tower Brace (79-04 All)-$84.99
SR Performance Caster Camber Plates (94-04 All)-$164.99
SR Performance Complete Rear Control Arm Kit (79-04 GT, V6, Mach 1)-$169.99
SR Performance Full Length Subframe Connectors - Black (79-04 All)-$87.99
QA1 K-Member Brace (94-04 All)-QA1 K-Member Brace (94-04 All)
Eibach Anti-Roll Sway Bar Kit (94-04 GT, V6, Mach 1; 94-98 Cobra)-$299.99
Cosmetic mods:
AmericanMuscle 1995 Cobra R Style Hood - Unpainted (99-04 All)-$479.99
Mach 1 Chin Spoiler (99-04 GT, V6; 99-01 Cobra)-$59.99
Steeda Functional Race Wing - Unpainted (01-04 All)-$299.99
Duraflex CVX Style Body Kit - Unpainted (99-04 All)-$649.99
Raxiom Smoked Projector Headlights - Dual CCFL Halo (99-04 All)-$224.99(pair)
Raxiom Smoked Tail Lights (99-04 V6, GT, Bullitt, Mach 1 & 03-04 Cobra; Excludes 99-01 Cobra)-$109.99(pair)
Exterior Blackout Kit (94-04 All)-$129.99
Black Racing Seats - Pair (79-13 All)-$499.99
Mustang Racing Seat Bracket Set (99-04 All)-$199.99
hi you can call me mater
Are you Millionaire?
All that is perfect
But by the time you have all that a cobra will come along and pull about 5 cars on you easy
A gt that's fixed like you will walk on you everyday too
what i'm saying is that all that money could be used to do a 4v swap,2v swap, cobra purchase
And I'd upgrade the 7.5 rear end to 8.8
03cristian
I know its a lot but this car was passed to me by my great grandpa so I want to keep/mod it for him and it only has to beat ricers since everyone in my city goes import and not American
Performance mods:
Supporting mods:
Cosmetic mods:
everything in red is a waste of time...
your cosmetic mods kind of ricer-ish
and... there is no fuel mods in this list.
Yeah halo headlights?
Ricer
And you have no fuel mods
with all that a ricer turbo with a2 step will eat you alive
03cristian
That's one hell of a build! I see how you want to keep the sentimental value of the car and not change the engine out. I still can't bare to get rid of my '95 GT. It just sits now, but it was my first car and not many people still have their first project car later in life!
I really just have two main suggestions. First is, pick up a rear from a GT of your year, then build that 8.8 instead of your 7.5. The Procharger will rip the 7.5 apart without much effort. Second, you'll have to upgrade your fuel pump if you want to run some boost. Any 255lph would be more than sufficient.
Good luck with your build!
Shane
what fuel pump should I get? and what turbo set up?
310lph pump
42lbs injectors
And a turbo duh, an intercooled gt35r turbo
03cristian
Discussion Starter #11
would 60lb injectors work? and I found a bbk 300lph pump that's a direct replacement for the stock pump
1 - 11 of 11 Posts
