1 - 9 of 9 Posts
I figure it shouldn't be a difficult job. It's leaking because I was on a dirt road to get to a gun range(Thats Texas for ya) and well it put a small bend on my pan and the sealant seem to have slipped out and well I leaked a little fluid. I love my Stang so I plan on fixing it.
I know I gotta jack her up, support the body on jack stands and the rear end as well.
Unbolt the pan and drain rear end.
correct the bend
apply Gasket maker(I got the Permatex Ultra Black gasket maker)
Bolt up pan
take off plug and put in about 3 quarts of differential fluid and done!
Am I doing it rite?
MM's Ginger
im pretty sure thats it, i had the same problem but i just took it to a shop because some idiot there didnt tighten up the bottom bolts and got it done for free:D
You missed one thing friction modifier, Fords part # F3TZ-19B546-MA (WSP-M2C196-MA). It's a 5 oz bottle, put that in first after you have it sealed up then refill with synthetic (3.75 pints) if you can afford it(Mobil 1 80W90). Just a suggestion I would use Permatex "ultra copper" for gasket maker, the material is orange and it’s in an orange tube. I have sealed up a few of those 8.8's and had no problem. Usually the diff covers get bent from jacking the car up under the chunk, if you pay attention and move the jack forward a little you can prevent this problem. I hope this helps.
  • Like
Reactions: Huxley
Rollin' 18/ pushin' 2
put a little permatex on the bolts as well, otherwise your fluid may "walk" up the threads and leak out from the bolts.
You may also want to wear some clothes you are not too fond of. I don't think gear oil ever really comes out of anything and the smell is extremely strong.
Well I got the Mobil 1 so that's no problem. The gasket maker i got is the Permatex Ultra Black gasket maker. I got the Ultra black since it hi-temp resistance and oil resistance. The differential cover got bent after i took it on a dirt road.
The Ultra Copper is the best gasket maker that Permatex makes, but what you have should do the trick, just need to go to Ford and get the modifier and you’re ready. Also you will need one of those $3 pumps at the parts store to pump the gear oil in with. Note when you jack the car up put your stand under the front control arm joints or the chassis so the rear end hangs down. Don’t put them under the axle tubs. It makes it easer to unscrew the plug in the chunk and refill the oil. Good luck.
1 - 9 of 9 Posts
