1 - 7 of 7 Posts
Speed Junkie
I haven't posted here much and have been wanting to share the build with you guys on here. I'm sure I've missed a lot so I'll update it in time.
My goal is to do a n/a break in and then put the Hellion turbo system on.
Details:
Holley HP EFI w/ Holley Touchscreen Dash
CHP 5.1L Stroker (Dished)
Stock Heads (Light Port/Polish, Oversized Valves)
Comp Cams Stg.2 (w/ Behive Springs)
Teem Breed Valve Covers
TFS TrackHeat Intake Manifold
Steel Adj. Cam Gears
MMR Billet Chain Guides & Tensioners
MMR Oil Pump w/ Billet Gears
FRP Shorty Headers
Fore Fuel Rails & FPR (-10 Feed -08 Return)
FRP Green 42#
03/04 Cobra Tank
Moroso Pan & Windage tray
Moroso Oil Accumulator
Super Moderator
Sweet man where did you get those pullies? what are your all out plans?
Speed Junkie
Thank you fellas! The pulleys are from SilverHorse Racing. The price wasn’t too bad and I was in the market to replace my stock idlers. I’m just hoping these last longer than the stock ones haha.
As far as plans for the car, I just want to build a fun street car. If all goes well during break-in, I’ll be installing a hellion turbo kit that I’ve had for many years from my other mustang. I doubt I’ll ever track the car but, some fun spirited mountain corner carving will definitely happen.
Speed Junkie
Quick update on progress: I’ve been fighting an issue with the starter wire at the ignition switch ~to~ starter relay. It loses signal sometime after the clutch safety switch. Tomorrow I’ll get that squared away. Has anyone else with Holley HP/Dominator run into the same problem? I’m thinking maybe it’s caused because I got rid of the factory ecu and gauge cluster?
Other than that, I’m going to fire it up for the first time by mid week. I got ‘Steven Kiehne’ (by recommendation) to write me a base tune for my setup and then go from there. If all goes well, I should have my turbo kit on soon. *Praying to the Motorsports gods*
1 - 7 of 7 Posts
